Ridekick electric-powered bike trailer
Discussion in 'Gear and Equipment' started by charliew, Jan 9, 2012.  |  Print Topic
  1. charliew
    charliew
    SUN
    Charlie
    Anyone tried a RideKick push trailer? Pushes you up to 19mph for $699.
  2. Geyatautsilvsgi
    push trailer
    Can't say that I have tried a push trailer, but Willie G & I lent our tandem to a couple in CA to use for a movie they were making. They had NO experience with a recumbent much less a tandem.:rolleyes9: They were supposedly going to hook up a trailer that pushed...to sort of be like an electric assist I think. However, they OVERLOADED the tandem and the trailer. Messed up the derailleur a few times and a few other incidents. In a nutshell it wasn't long before they wound up having to ship the tandem back...
  3. Lawnchair Limo
    Lawnchair Limo
    Longbike Gulfst
    Dwight
    We used to live in Cincinnati a few years back. We met a couple of older gentlemen on trikes with powered trailers. They got 'em from Fairfield Cyclery in Fairfield, OH. I don't know if they still sell 'em but it might be a good place to start looking.
    :cool9: Yep, certainly looks like they do... :jiggy9:
  5. Mtwnrocket
    Yikes! I get nervous just thinking about being pushed from behind at varying angles and all that pressure applied to one side of my rear wheel. I like the idea of a Husky pulling from the front much better.
  6. mark_w
    mark_w
    CO
    Kona
    Mark
    I too thought that pushing a bike would be awkward, but found that mounting to the wheel magically makes the assist transparent. Riders are comfortable after about 10 seconds, but my writing shouldn't be the closing argument. Ride one.
    Here are a few more links to describe how the power trailer works with recumbents (both 2 wheel and trikes.)
    Larry at bentrideronline published a comprehensive blog about his ride. Google search bentrideronline and ridekick it to find the article "who needs gas".
    And the recumbenttrikestore.com has a good description online. Call Chip for his personal opinion, he has an excellent shop set up.
    Riders have written about being able to extend their rides with a trailer, not to mention running errands on a bike instead of driving with the boost and cargo carrying capability.
    Ride On!
    :welcome4: aboard Mark! Thanxx for posting the info about the ridekick. :thumbsup: I embedded some links into your post, to make it easier for others to read more about it. With just a few more posts under your belt, you'll be able to do the same in the future.
  8. A.D.
    Compact Wheezy trailer
    On-bike electric drives like the ConoDrive and Electron Wheel aren't the only means of adding some electric muscle to your pedaling. Powered bike trailers like the compact Ridekick or cargo-hauling Brouhaha bring their own drive wheels and give your pedaling a little extra oomph. The new, UK-designed Wheezy is a compact, easy-to-use electric trailer option. Make your bike a little more Wheezy and you can expect to be a little less so.
    Since the Wheezy is self-powered and doesn't offer any built-in room to transport anything, it really isn't a trailer by any stretch of the definition, save perhaps for when it runs out of power. Its designers description of an electric auxiliary wheel is more accurate, but also clunky. We'll just stick with Wheezy.
    The Wheezy is a compact unit that includes a single wheel with 9 x 3.5-in all-terrain tubeless tire, detachable battery pack, brushless electric hub motor, microcontroller, built-in charger with cable, and draw bar. A stainless steel chassis protects the components. Its 26-lb (12-kg) curb weight is a significant drop when compared to the Ridekick's 40-lb (18.1 kg) figure.
    The Wheezy has been designed with both pedal sensor and thumb throttle options. The pedal sensor works like a pedelec bike, prompting the microcontroller to start the motor when you start pedaling. The thumb throttle lets you control motor power directly.
    The initial set-up requires a bit of wrenching around, but after that, the Wheezy secures and detaches in a matter of seconds. The Wheezy mounting adaptor swaps out for the left nut on the rear bike wheel and the pedal sensor or thumb throttle gets mounted and wired back to the rear wheel.
    After that, the Wheezy simply…
    continued
  9. Geyatautsilvsgi
    That is an unusual little gadget, don't know if I would use it though.
  10. Mtwnrocket
    Unusual maybe, little: not so much. Larger versions essentially equal to a recumbent's weight. Doesn't look like they'll be on the market before next summer, and if then over $500. If I need a powered vehicle I'll convert my Trikke T-8 to a pon-e.
  11. Buddy Bishop
    Back in business
    Appears Ridekick is back in business. They were down for a while. If I didn't have assist, I would consider one.
    BTW, assist for my use is to maintain uphill speed. My average speed is 10mph. I'm not at all concerned about that. I'm a happy camper and life is good.
  12. A.D.
    You're right Buddy, per their website:
  13. ancient11
    ancient11
    Royston
    KMX Cobra
    Thad
    Latest news that I have
    They have said they will be producing by March 2016 but personally I am looking for March 2017.
