CLBot SUN EZ SPORT AX LIMITED RECUMBENT BIKE - $600 (Spring Hill, FL)
Discussion in 'Buy, Sale or Trade' started by CLBot, Jul 18, 2022.  |  Print Topic
    Easy Rider Designed aluminum version with upgraded components.
    Excellent Condition $600 OBO
    Long wheel Base
    Ideal for touring, commuting and long recreational rides, they offer remarkable handling at any speed. With a relatively high seat, lots of adjustability and a low Bottom Bracket give you a pleasant sense of stability and control.
    EZ-SPORT AX SPECIFICATIONS
    WHEEL BASE 62_ (157.5cm)
    OVERALL LENGTH 85 1/2_ (217cm)
    SEAT HEIGHT 26.5_ (67cm)
    FRAME 7005 Tig Welded Aluminum
    fork Full Cro-Mo
    BB Sealed Cartridge 68mm
    CRANK Sun Bicycle Alloy 170Ñ52-42-30
    F. derailleur Microshift
    R. DERAILLEUR SRAM X.9
    SHIFTER Sram X.9
    freewheel Sram PG-930 11-32 9sp
    PEDALS Alloy cage
    brake FRONT Avid SD-5 Linear Pull
    BRAKE REAR Avid SD-5 Linear Pull
    BRAKE LEVERS Avid SD-5 Linear Pull
    26_/20_ wheels for long range cruising
    headset 1 1/8_ Aluminum
    handlebar Steel w/2 Bottle Braze-ons
    STEM Alloy 240mm Recumbent 2pc
    HUB FRONT Formula Sealed
    HUB REAR Formula Sealed cassette
    RIM FRONT 20Ñ1.50 36H Alloy CNC Side
    RIM REAR 26Ñ1.50 36H Alloy CNC Side
    SPOKES 14g. Stainless Steel
    TIRE FRONT 20Ñ1.50 Kenda Kwest 100psi
    TIRE REAR 26Ñ1.50 Kenda Kwest 100psi
    SADDLE Contoured Foam w/Tri Color Top
    SEAT SLIDE Alloy
    SEAT BACK Alloy Cool Back Adjustable w/ Bottle Braze-on
    WEIGHT 35 LBS
    WEIGHT LIMIT 300 lbs
    NOTICE: Above text is a COPY of a Craigslist ad.
    In most cases, the seller will not have a user account on Recumbent Riders.
    Simply click the More... link above to see the original ad.
