CLBot Actionbent JetStream III SWB USS Recumbent Bicycle - $900 (Grand Forks, MN)
Discussion in 'Buy, Sale or Trade' started by CLBot, Jun 26, 2022.  |  Print Topic
    Single owner - Like New Condition, ready to ride, Recumbent Bicycle. This is an Under-seat Steering (USS) Short Wheelbase (SWW) Recumbent bike with 27 speeds. Without accessories, the advertised bike weight is 32 LBS. There is a mono front headlight next to a trip computer, and rear lighted tail light all in good working condition. I had it customized with fenders, rear carrier rack, and kick stand. This bike was fitted for a 6 ft tall person + or -, rated for 250 lbs or under. The full cr-moly frame can telescope longer or shorter so it can be adjusted for a taller or shorter person by loosening the main frame clamp and sliding it out or in for a taller or shorter person. If changing the frame, more chain will need to be added or removed. This particular bicycle design is considered to be the fastest if you're into speed. It is best suited for paved flat roads with few hills or tight turns, perfect for our Red River Valley farmland area. If a traditional upright bike frame is uncomfortable to ride but a recumbent position is not, or your in need of a new recumbent, this is as close to new as you'll find on the used market. This is not a beginner's recumbent bike. If you've never owned a recumbent bike, I would suggest something different for your first recumbent. Once you acquire some experience and get comfortable with the steering and balance, riding this bike is like sitting on a recliner with a head rest. This is by far the most comfortable bicycle to ride I've ever had and it even worked well to pull a child's trailer. $900 OBO takes it.
    Factory Features
    Wheelbase: 39"
    Overall length: 60"
    Weight: 32 lb
    Frame: Full cr-moly
    fork: cr-moly
    Seat: Ultra Light FRP (Fiber Glass-Reinforced Plastic) Contoured padded full back rest with padded head rest
    Seat Height: 22" ground to base
    handlebar: Alloy
    Shifter: Avid hand brakes and thumb shifters
    Brakes: Linear pull V-Brakes
    Drive Train : 27 Speed Shimano Deore/MEGA
    F/derailler: Shimano 3 speeds
    R/derailler: Shimano Deore 9 speeds
    Crank: Truviativ 170mm "ISOFlow Powered by SRAM" 52/42/30 Hi-Perf alloy
    freewheel: SRAM 11-34 9 speeds
    Hub: alloy
    Spoke: #14 stainless
    wheels: SPEEDMAX stainless hubs
    Rear Tire: 26 x 1.25 Kenda KWest 100 psi high pressure
    Front Tire: 20 x 1.25 Kenda KWest 100 psi high pressure
    Quick release front and rear wheel axles
    Added Accessories
    BIKE Computer Topline SIGMA BC 1009
    Cygo-Light Red Rear Safety Light with Pulsating/Constant settings
    1 UNO Opticube Cat Eye UNO front single beam headlight
    Planet Bike Custom fitted Front and Rear fenders
    delta rear carrier rack
    NUVO Kick Stand
    Seat mounted bottle holder
    NOTICE: Above text is a COPY of a Craigslist ad.
    In most cases, the seller will not have a user account on Recumbent Riders.
    Simply click the More... link above to see the original ad.
